ā11-10-2011 12:52 AM - edited ā03-07-2019 03:18 AM
Hi, i am facing a strange issue on cisco 2950 .
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA9, RELEASE SOFTWARE (fc1)
suddenly my phone stopped working for DTMF tone, i mean when i dial a conference bridge lets say 6565 and then it ask for conference bridge code lets say 12345, it doesnt recognize the code and says code is invalid, SIP Proxy is Asterisk in this case.
Currently my cisco switch port is configured for dual data + voice vlan, where DTMF dont work, sample config below
int fa0/10
switch mode access
switch port voice vlan 2/// for voice
switch port access vlan 5/// for PC
spanning-tree portfast
exit
When i change it to simple access port, DTMF starts working,
int fa0/10
switch mode access
switch port access vlan 2
exit
any idea what could b e the cause?
ā11-10-2011 03:02 AM
Hi ahmad82pkn, I think there is no direct relationship between Voice VLAN and DTMF problem. If you describe your infrastructure in detail, we can help you.
Ali TADIR
ā11-11-2011 04:12 AM
Setup is very basic.
Asterisk SIP PBX connected to 6509 CORE.
2950 is trunked with 6509
Phones are conneted to 2950 having issues.
Where as same extensions work fine with voice vlan setting from different office coming to same PBX, so it clarfies me, its not extension or PBX issue, but something to do with the switch
