07-25-2013 05:20 AM - edited 03-07-2019 02:35 PM
I try to dual attach a 2960 to my 2 nexus on which peer link and keepalive are OK.
The ports are down (notconnect) on the 2 nexus, and I don't see any config error !
Another detail, when the SFP is plugged into the port, led is orange, whereas when I connect the fiber, led turns off
I join few config about the portchannel, and shows relative to this :
NEXUS 1 :
NX01# sh run
interface port-channel102
description *** VPC to 2960 ***
switchport mode trunk
switchport trunk native vlan 900
switchport trunk allowed vlan 1-500,520-4094
spanning-tree port type normal
spanning-tree guard root
speed 1000
duplex full
storm-control broadcast level 5.00
service-policy type qos input TRUSTED-5K
vpc 102
interface Ethernet1/11
description *** to 2960 ***
speed 1000
duplex full
channel-group 102 mode active
NX01# show vpc 102
vPC status
id Port Status Consistency Reason Active vlans
102 Po102 down* success success -
NX01# show vpc consistency-parameters interface port-channel 102
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
Shut Lan 1 No No
STP Port Type 1 Normal Port Normal Port
STP Port Guard 1 Root Root
STP MST Simulate PVST 1 Default Default
Allowed VLANs - 1-6,16-18,20-23,30,100 1-500,520-4094
,111,120,130-132,140-1
41,145,150,160,170,253
,702,704,716-717,740,7
42-744,760,795-797,800
-804,830,899-900
Local suspended VLANs - - -
NEXUS 2 :
NX02# sh run
speed 1000
duplex full
vpc 102
speed 1000
duplex full
NX02# show vpc 102
vPC status
102 Po102 down* Not Consistency Check Not -
Applicable Performed
NX02# show vpc consistency-parameters interface port-channel 102
Legend:
Shut Lan 1 No No
Allowed VLANs - 1-500,520-4094 1-6,16-18,20-23,30,100
-804,830,899-900
2960 conf :
c2960# sh run
interface Port-channel1
description *** VPC to NEXUS ***
switchport nonegotiate
interface GigabitEthernet1/0/25
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
channel-group 1 mode active
interface GigabitEthernet1/0/26
priority-queue out
mls qos trust dscp
Please help if you find any configuration errors or tips to bring up the portchannel.
Solved! Go to Solution.
07-25-2013 12:24 PM
If the optics are working when you are close to the switch with a 2 meter cable, then your optics are good. When you are 100 meter far a way from the switch and the same optics are not working, you most likely have an issue with your fiber.
Are you using patch panels?
07-25-2013 06:29 AM
Can you verify your fiber and the optics are good?
You may have to switch the fiber strands around on one side of the connection (2960 side) and test again.
what is the output of "sh interface Ethernet1/11"?
what is the output of "sh vpc"?
07-25-2013 08:46 AM
When I connect the 2960 by a 2m long direct fiber on the 2 nexus (LC/LC with GLC-LH-SM SFP), it is OK (I have had to do a shut/no shut on the int Po102).
As this result is good, and Po brings UP on the both Nexus, I moved the 2960 to its final location (100m far away). But in this configuration with the same SFP, link doesn't go up.
- Fiber strands are switched on the 2960.
- Here is the output of sh int eth1/11 :
Ethernet1/11 is down (Link not connected)
Dedicated Interface
Belongs to Po102
Hardware: 1000/10000 Ethernet, address: 547f.eef5.0f12 (bia 547f.eef5.0f12)
Description: *** to 2960 ***
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
reliability 254/255, txload 1/255, rxload 1/255
Encapsulation ARPA
Port mode is trunk
full-duplex, 1000 Mb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped 00:52:01
Last clearing of "show interface" counters 14w2d
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
424 unicast packets 1192 multicast packets 8 broadcast packets
1624 input packets 98945 bytes
0 jumbo packets 0 storm suppression bytes
948 runts 0 giants 7 CRC 0 no buffer
955 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
13523 unicast packets 19198 multicast packets 156264 broadcast packets
188985 output packets 39400416 bytes
4114 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
4 interface resets
I checked the 85m fiber with a TP-LINK fiber converter and this is OK, is there a SFP power problem ?
07-25-2013 12:24 PM
07-26-2013 01:55 AM
Problem is solved now.
When I opened the optic tray which was installed by another subcontractor, I see fiber SC connectors were not plugged totally into intermediate female/female SC connectors, so the light wasn't redirected well into pigtail...
It seems that TPLINK fiber converter have less requirements about link quality than Cisco SFP!
Thank you for your help.
