Dual Core 6509's and how to offer Hot Standy and redundancy
Kevin Melton
Level 2
Level 2
Hello
I am working at a customer site that wants to put a 2nd 6500 box in their Core. they have asked that we prepare a document or presentation that shows how having the Dual Core switch arrangement will be able to benefit their servers for availability.
Can anyone direct me to any documentation or Case Studies that describe this scenario. I know this is a common configuration; I just need more detail...
Thx
Jon Marshall
Attached is a link to Cisco's SRND (Solution Reference Network Design) documents. These cover a multitude of different areas. Have a look at the Data centre section as a starting point.
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_program_category_home.html
You don't say whether the server are directly connected into the 6500 core switches. If so adding a second would allow you to dual hone your servers to two different switches. Having a pair of 6500 switches will give you far more scope for redundancy etc..
Jon
Thanks for your data.
The recommendation is your 2nd paragraph is exactly what I need to put into the customer's project plan.
Glad to have helped. Good luck with the presentation.
Jon
