Dual Internet with BGP Failover
mikegrous
Level 3
Level 3
1 Router Has:
     2 /24 Public IP blocks.
     2 ISPs.
     Both public blocks will get sent up the the ISP. (We will call them...Public Subnet Block A and Block B)
So for Block A or B (depending where you are on the internet) your traffic will take 1 ISP path or the other. When 1 ISP Peer fails how long will it take for the internet to reconverge so that all traffic for public subnet block A and B only come through that 1 remaining ISP?
Are we talking seconds/ minutes/ hours
Vaibhava Varma
Level 4
Level 4
Hi mikegrous
My viewpoint on above scenario
Lets assume the below setup which will resemble the Interet Scenario
     --eBGP------ISP1----------iBGP-------ISP1----------eBGP------
(X)CE1        CE2
     ---eBGP------ISP2----------iBGP------ISP2---------eBGP------
Lets say Prefix X is sent via ISP1 as preferred and via ISP2 as Backup and received by CE2 in same way. Now when the CE1-Link_to-ISP1 goes down the below events would be required at CE2 to get updated of the Prefix X withdrwal via ISP2
a) At ISP2 (facing CE1) Next-Hop_Tracking to delcare eBGP session with CE1 as  down and withdraw the Prefix X (Default 5 seconds)
b) ISP2 (facing CE1 advertising the withdrwal of Prefix X in the iBGP Update ( Default advertsiement interval 5 seconds)
c) ISP2 (facing CE2) updating its RIB with Prefix X withdrwal ( Default BGP Scan Time 60 seconds )
d) ISP2 (facing CE2 advertising the withdrwal of Prefix X in the eBGP Update ( Default advertsiement interval 30 seconds)
e) CE2  updating its RIB with Prefix X withdrwal from ISP2 ( Default BGP Scan Time 60 seconds )
So in my personal view everything happens at T0 = 0 seconds the max time should be ( 5 + 5 + 60 + 30 +60 =160 seconds = 2 mins 40 secs)
So, as it seems from above the worst case convergence would be ~ 3 mins.
Hope this helps something in your understanding. Would be nice to hear someone's else view on this interesting questions and get a better understanding on anything missed.
Varma
Edison Ortiz
It depends on the ISP and how aggressive their BGP scan intervals are. With that said, reconverging should take a minute or two max.
