Dual Trunks Between Stacks
I have 2 3750 switch stacks which I would like to have redundant trunks between them.  This will provide two physical connections traveling through different geographical locations for redundancy in the event that a cable is severed.  I couldn't find anything in regards to setup/config.  Does it matter if I go stack1/switch1 to stack2/switch1 and stack1/switch2 to stack2/switch2 or should they cross to opposite switches like a stack cable?  I don't think that should be necessary, but couldn't find any documentation.  Should there be an issue with loops?
Thanks!
Kevin Dorrell
Level 10
Level 10
I had exactly that and it was working very well. Make a cross-chassis etherchannel on each end and it does not matter whether you cross the connections or go parallel.
Sent from Cisco Technical Support Android App
I have also implemented the same and it is working fine.
You will not have face any issues
Ahmed Umair
Thanks for the response Kevin.  So to reap the full benefits use LACP or active mode?  I know PAgP will not work in this case.
Kevin Dorrell
Level 10
Level 10
I would set active on both sides. Do NOT be tempted to force "on", and keep spanning tree for safety.
