03-07-2012 03:24 PM - edited 03-07-2019 05:25 AM
Hey everyone,
Need more advice please. If you didn't already know I am a 3rd year Networking and Systems Support student so please don't laugh if I am being a complete nooby no sense! lol.
I am having a some difficulty VLAN addressing on the dual the layer 3 switches. On both DLS switches I beleive the VLAN IP addresses should match each other?? Or am I wrong in saying do?? Reason I ask is because I am being displayed with Duplcate addresses of the VLANs. I have DLS1 & DLS2 configured with the following VLANs:
interface Vlan1
ip address 172.16.0.1 255.255.255.0
interface Vlan100
ip address 172.16.1.1 255.255.255.0
ip helper-address 172.16.0.10
interface Vlan200
ip address 172.16.2.1 255.255.255.0
interface Vlan300
ip address 172.16.3.1 255.255.255.0
interface Vlan400
ip address 172.16.4.1 255.255.255.0
interface Vlan500
ip address 172.16.5.1 255.255.255.0
interface Vlan1
interface Vlan100
interface Vlan200
interface Vlan300
interface Vlan400
interface Vlan500
hostname DLS1
ip routing
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree vlan 1,100,200,300,400,500 priority 24576
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport mode trunk
interface FastEthernet0/6
interface FastEthernet0/7
channel-group 1 mode desirable
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Port-channel 1
spanning-tree portfast disable
interface Vlan1
interface Vlan100
interface Vlan200
interface Vlan300
interface Vlan400
interface Vlan500
ip classless
line con 0
line vty 0 4
login
end
hostname DLS2
ip routing
spanning-tree vlan 1,100,200,300,400,500 priority 28672
interface Vlan1
interface Vlan100
interface Vlan200
interface Vlan300
interface Vlan400
interface Vlan500
ip classless
line con 0
line vty 0 4
login
end
Can you see of I have done this wrong? If someone could check my configs too that would be great.
Thank you!
03-07-2012 03:35 PM
Hi John,
I think you might be getting confused with a function / technology called HSRP.
Basically if you have two layer 3 switches serving clients and want a HA configuration where if one fails the other will take over Layer 3 forwarding operations you need HSRP (which sounds like what your trying to achieve).
So in terms of your configurations each DLS should have a different IP for each Vlan and then under each Vlan interface you configure a HSRP group with the "virtual IP" that clients will use as a default gateway.
I hope this makes some sense if you want to know more about HSRP let me know.
Dunc
03-07-2012 04:10 PM
Thanks Duncan,
Yeah I will be using HA in terms of Gateway Load Balancing Protocol I haven't gotten that far as I am doing a top down design and unfortunetly PacketTracer does not support HSRP or GLBP. Configuration will need to happen in the lab but until then I am getting familar with the commands. Presentation is in 6 weeks to show a fully operational campus network with 5 branch offices. Plenty of time. I hope!
Thanks again.
