dynamic ip's for users
suthomas1
Level 6
Level 6
This network has lan users connected to the layer 3 6500 switch. DHCP is configured on a server , whose gateway is the layer 3 switch.
if the lan users need to get their ip address from the dhcp configured on the server, what configuration should be done on the switch to achieve this.
thanks in advance!
cadet alain
under each vlan interface put a ip helper-address x.x.x.x where x.x.x.x is ip address of server
Regards.
Alain
Correct ..
if you have Two Dhcp servers give both primary and secondary DHCP servers using the same command one by one .
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just wanted to add the helper statements should only be needed on the VLAN interfaces with DHCP clients if the DHCP server isn't on the same subnet.
Further, if the VLAN gateway IP is a secondary IP, there's another configuration change you need to make as the default configuration only supports the primary interface IP.
