Dynamic Switch Routing
Douglas Turner
I am using a 3750 with a router provided from Time Warner. I am unable to access the internet from any devices and I believe it is from the IP address changing on the router. How can I configure the switch to maintain the connectivity?
5 Replies 5
The ISP supplied router should do the NAT for you.
can you get to the internet if you plug a device directly into the router?
do your devices pickup an IP address from the router?
and what is the config of the 3750?
Thank you for your response and assistance.
I am able to access the internet with a direct connection and all devices receive an IP
On each fast Ethernet port I have created vlan 3 with switchport access.
gig1 is currently no switchport because I have been trying to follow other instructions that didn't work.
interface Vlan3
 ip address 192.168.0.30 255.255.255.0
ip default-gateway 192.168.0.1
ip classless
ip http server
ip http secure-server
Is Gig1 the uplink to your TWC router? If so, you should set to to be an access port just like the fast Ethernet ports. Edit: it should also be a part of vlan 3 as well.
This is what I had set up before I made changes.
interface FastEthernet1/0/24
 switchport access vlan 3
 switchport mode access
interface GigabitEthernet1/0/1
all of the fast Ethernet ports are the same. gig 1/0/2 is not being used so it is not configured.
Which interface of the switch connects to the Time Warner router?
If you connect a PC to one of the switch ports what IP address does it get? And what does it get as the default gateway address?
If you connect a PC to one of the switch ports can the PC ping the switch address of 192.168.0.30?
If you connect a PC to one of the switch ports can the PC ping the default gateway at 192.168.0.1?
Rick
Rick
