eBGP between VASI-Pair
HUBERT RESCH
Level 3
Level 3
Is there a way to run eBGP within a VASI-Pair on ASR1000
Thx
Hubert
Yigal Dekalo
You can't do iBGP for sure
You can run a simple test
Try to telnet through the VASI
If it works most like BGP will work
@Yigal: iBGP is supported and should work, the reason why eBGP is not configurabel is because its only possible to configure one "router bgp xxx"
statement.
Each VASI interface will be attached to 2 different VRFs (it will not work other way).
So, if VASIL 1 is on VRF foo and VASIR 1 is in blobal, you will configure the peer as a eBGP PE-CE right?
I don't see how iBGP will work when the 2 interfaces MUST be on different VRFs (VRF Aware System Interface), but I would be glad to see that.
