Ehherchannel with with different media types
Smailmilak83_2
can I use etherchannel between two switches with mixed media types?
SW1: 1 Copper and 1 Fiber   ----- One channel group
SW2: 1 Copper and 1 Fiber    ----- One channel group
Jon Marshall
Yes you can. Etherchannel doesn't care about the physical media as long as the speed and duplex settings are the same.
Jon
5 Replies 5
Jon Marshall
Jon
Thank you!
I hope the only difference between the member ports is the media-type. If you are trying to use ports from different type of modules (which has different queue architecture) then we need to configure "no mls qos channel-consistency" under port-channel interface.
- Yogesh
There will be a GLC-SX-MM and normal ethernet interface for copper.
Thats should be fine.
Actually, I was referring to the linecards in the switch.
- Yogesh
