Eigrp 2 successors with same FD
opnineopnine
Hi all
I have the issue in a network when I do a "show ip eigrp top" I get this output
P 172.16.203.136/29, 2 successors, FD is 257792
        via 172.16.100.5 (257792/30976), GigabitEthernet0/0.251
        via 172.16.100.133 (257792/30976), GigabitEthernet0/0.903
Both paths are the same, how will the traffic be handled?
Thanks.
Jon Marshall
You should see both routes when you do a "sh ip route 172.16.203.136".
And by default the router will use both paths on a per destination basis.
Jon
when I do the sh ip route in one of the routes I have a (*)
thanks
I'm not sure what you are asking.
There is no issue, you simply have multiple equal cost paths.
If I remember correctly the * simply indicates which route the L3 device used last ie. it should switch between the routes.
Why do you think this is an issue ?
Jon
Hello
sh ip route 172.16.203.136 | in  traffic
You should see a traffic share of 1, which would then i guess mean traffic will be LB on a per destination address.
However this can be manipulated into unequal L/B  to any ratio you wish by some eigrp calcualtions
If you would like to see an example I would happy to provide one:
res
Paul
Kind Regards
Paul
