Bookmark
Subscribe
1206
EIGRP and BGP routing help
sgoldschmidt
Hello Everyone, i am looking for some help to get eigrp routes to take precedense of eigrp routes.
I have an adtran distributing bgp routes from my mpls to a cisco c1700 which is also recieving eigrp routes from my cisco 2600 over my point to point connection point to point connection
my issue is when there is a slight hickup in the PTP line my bgp routes are taking precedence from my adtran to my c1700 over writing my eigrp from c2600 to c1700.  i need to make my c2600 eigrp routes take precedence over bgp and the only why i can get this to reset is to reload my c1700.
any help on this would be appreciated
my cisco 2600 is config like this for eigrp:
router eigrp 100
network 10.0.0.0
network 192.168.4.0
no auto-summary
my cisco 1700 is bgp and eigrp:
router eigrp 100
redistribute bgp 65005 metric 1500 20 255 1 1500
network 10.0.0.0
network 192.168.1.0
no auto-summary
router bgp 65005
no synchronization
bgp log-neighbor-changes
redistribute eigrp 100
neighbor 10.43.144.2 remote-as 65001
neighbor 10.43.144.2 soft-reconfiguration inbound
neighbor 10.43.144.2 distribute-list trc-in in
neighbor 10.43.144.2 distribute-list trc-out out
no auto-summary
my adtran is
router bgp 65001
  no auto-summary
  no synchronization
  network 10.43.144.0 mask 255.255.240.0
  network 192.168.1.0 mask 255.255.255.0
  redistribute static
  redistribute connected
  neighbor 10.43.144.1
    no default-originate
    update-source loop 11
    remote-as 65000
  neighbor 10.43.144.4
    remote-as 65005
Your problem is that the cost of the routes received by the 2600 is higher then the routes redistributed from BGP.
So check the metric of the routes received in normal times by the 2600 , and use a number higher then this metric when you redistribute from BGP.
Dan
fb_webuser
Level 6
Level 6
Please decrease the "delay" metric on the interface to make EIGRP route preferred over the BGP route.
run show interface command and note down the delay value in both the interfaces which is like this : DLY 1000 usec.
then run a command like this :
NJ-R2#config t
Enter configuration commands, one per line. End with CNTL/Z.
NJ-R2(config)#int fa0/0
NJ-R2(config-if)#delay 100
NJ-R2(config-if)#
Hope it helps. Delay is preffered metric to play with in EIGRP versus Bandwidth.
Posted by WebUser Neeraj Jagga from Cisco Support Community App
Thanks for getting back to me.
Do i perform the dely reconfig on the 1700 or 2600?
my dely for ser0/0 is 2000 usec and fa0/0 100 usec for both 1700 and 2600
dslice
Is the prefix learned as an external route over the PTP link? Are you redistributing EIGRP Into BGP as well? There could be multiple factors at work here. Could you supply the output of "show ip eigrp topo " for the prefix in question both with it working and with it broken?
