EIGRP ASA 5510 and 1841 ISR
Felix Bowman
Greetings.
Our network setup looks like this:
ASA 5510 --->> E0/1 (1841 ISR) E0/0 --->> Catalyst Switch
We've recently added an ASA 5510 to the network to replace the old hardware firewall. We have multiple VLANs setup on E0/0 of the 1841. I've attempted to configure EIGRP on the ASA and the ISR so that they would share the routing information between themselves but it didn't work. When I checked for neighbours, none were discovered/
Is it possible to do EIGRP this way?
2 Accepted Solutions
Jon Marshall
Can you also confirm your ASA is not -
1) running in multiple context mode
2) running in transparent mode
Jon
So 192.168.15.x is the network connecting the ASA to the router ?
Is there any reason you have auto-summary on ? if not can you turn it off on both devices eg.
router eigrp
no auto-summary
also have you tried to debug eigrp on the router to see what it thinks is happening ?
Jon
8 Replies 8
Giuseppe Larosa
Hello Felix,
EIGRP support has been added but it was not present in first ASA software versions
see
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008086ebd2.shtml
you need version 8.0 or better for EIGRP support on ASA
Hope to help
Giuseppe
The ASA has the most recent images.
Jon Marshall
Can you post EIGRP config for firewall and router ?
Jon
Here are the configuration lines:-
ASA
router eigrp 1
network 192.168.15.0 255.255.255.0
redistribute static
ISR
router eigrp 1
redistribute static
network 192.168.5.0
network 192.168.13.0
network 192.168.14.0
network 192.168.16.0
network 192.168.17.0
network 192.168.18.0
network 192.168.19.0
network 192.168.22.0
network 192.168.23.0
network 192.168.24.0
network 192.168.26.0
network 192.168.27.0
auto-summary
router eigrp
no auto-summary
Jon
This seemed to be it. The routes have showed up.
Thank you both for taking the time out to look at and respond to my question. I appreciate it very much.
Jon Marshall
Jon
The ASA is running in routed mode and single context mode.
