Eigrp control plane bug
There is a bug with EIGRP with control plane ICMP traffic . ICMP traffic is not working from 2960XR from one particular subnet . It started working after I removed the eigrp neighbor from the switch.As a workaround, we have blocked the route and traffic has been passing through the default route .
Is there a bug for EIGRP control plane ICMP traffic ?
8 Replies 8
balaji.bandi
Not that we are aware of any bug like that, what is the version of code running on device?
If that is only a subnet, I will check any loop In the redistribution, check where it learning from.
how extensive is this network?
BB
Version 15.2(7)E2
It's a stack switch and it's connected to the ISR routers 4331 and 4321. An Eigrp neighbor is formed between both the routers .
the routers connected is the master switch in the stack ?
Do you sample IP range which was not worked, what was the routing table at the time of issue /?
BB
can I see topology ?
PFA.
do you use router port or use SVI to connect SW to both Router ??
yes , SVI only .
both router must config with same subnet as SVI of SW
do
show ip eigrp neighbor
can you see both router IP ??
