EIGRP %DUAL-5-NBRCHANGE:
ubsaccount
I'm pulling my hair out trying to figure out why Packet Tracer is doing this..
I keep getting this error
%DUAL-5-NBRCHANGE: IP-EIGRP 10: Neighbor 10.0.50.253 (Vlan50) is down: retry limit exceeded
%DUAL-5-NBRCHANGE: IP-EIGRP 10: Neighbor 10.0.50.253 (Vlan50) is up: new adjacency
I have F0/0 on R1 connected to a 3550 layer 3 switch F0/24
 If anyone can help me this would be greatly appreciated.  I have been working on this for 2 days now and have googled everything and tried everything.
Switch 1
router eigrp 10
network 10.0.50.0 0.0.0.255
network 10.0.70.0 0.0.0.255
network 10.0.80.0 0.0.0.255
network 10.0.100.0 0.0.0.255
network 172.16.20.0 0.0.0.3
network 172.16.20.4 0.0.0.3
network 172.16.100.0 0.0.0.255
network 10.0.10.0 0.0.0.255
network 172.16.20.8 0.0.0.3
no auto-summary
Router 1
router eigrp 10
no auto-summary
Switch 2
router eigrp 10
no auto-summary
Hi, ubsaccount.
As I see there is no problem between routers and switches because your log have errors with one of your end users. You have a 172.16 network for connection your router with switches, but you have a problem with somebody at vlan 50 (10.0.50.253). There could be a eigrp process at this device 10.0.50.253 but your switch can't establish a neigbouship with it.
If you want exclude vlan50 from your eigrp process you can use this lines:
router eigrp 10
 passive-interface vlan50
Best Regards
5 Replies 5
AllertGen
Level 3
Level 3
Hello, .
Can you also post a configuration of the interfaces from the both sides?
Best Regards.
CORE SWITCH F0/24 to Router F0/0
interface FastEthernet0/23
no switchport
ip address 172.16.20.9 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/24
no switchport
ip address 172.16.20.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport mode trunk
switchport nonegotiate
spanning-tree guard root
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.0.10.254 255.255.255.0
interface Vlan50
ip address 10.0.50.252 255.255.255.0
ip helper-address 10.11.11.1
ip access-group 100 in
standby version 2
standby 50 ip 10.0.50.254
standby 50 priority 150
standby 50 preempt
interface Vlan70
ip address 10.0.70.252 255.255.255.0
ip helper-address 10.12.12.1
standby version 2
standby 70 ip 10.0.70.254
standby 70 priority 150
standby 70 preempt
interface Vlan80
ip address 10.0.80.252 255.255.255.0
ip helper-address 10.13.13.1
standby version 2
standby 80 ip 10.0.80.254
standby 80 preempt
interface Vlan90
ip address 10.0.90.252 255.255.255.0
standby version 2
standby 90 ip 10.0.90.254
standby 90 preempt
interface Vlan100
ip address 10.0.100.252 255.255.255.0
ip helper-address 172.16.100.1
standby version 2
standby 100 ip 10.0.100.254
standby 100 preempt
router eigrp 10
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.100.1
ROUTER Config
interface FastEthernet0/0
description Linke to DLSW1
ip address 172.16.20.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description Link to DLSW2
ip address 172.16.20.6 255.255.255.252
duplex auto
speed auto
router eigrp 10
no auto-summary
Second Core Switch F0/24  going to Router  F0/1
no switchport
ip address 172.16.20.10 255.255.255.252
duplex auto
speed auto
no switchport
ip address 172.16.20.5 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.0.10.253 255.255.255.0
interface Vlan50
ip address 10.0.50.253 255.255.255.0
ip helper-address 10.14.14.1
standby version 2
standby 50 preempt
interface Vlan70
ip address 10.0.70.253 255.255.255.0
ip helper-address 10.15.15.1
standby version 2
standby 70 preempt
interface Vlan80
ip address 10.0.80.253 255.255.255.0
ip helper-address 10.16.16.1
standby version 2
standby 80 priority 150
standby 80 preempt
interface Vlan90
ip address 10.0.90.253 255.255.255.0
standby version 2
standby 90 priority 150
standby 90 preempt
interface Vlan100
ip address 10.0.100.253 255.255.255.0
ip helper-address 172.16.20.2
ip helper-address 172.16.20.6
standby version 2
standby 100 priority 150
standby 100 preempt
router eigrp 10
no auto-summary
Hi, ubsaccount.
router eigrp 10
Best Regards
WOW.... that worked... Thanks a bunch!!! WOOHOOO been working on this for 3 days now. You solved it in minutes.
Hello
Your config posting is very convoluted - can you
repost a small topology diagram  to make it more clear.?
Regards your issue- You may have possible layer 2 issue here.
Can you ping the neighbour  10.0.50.253 ?
Remove the acl from vlan 50  and see if this rectifies it, if it does then check  your allowing EIGRP
sh ip access-list
sh ip eigrp neigbours
res
Paul
Kind Regards
Paul
