03-12-2013 05:25 PM - edited 03-07-2019 12:12 PM
Hi All,
I see these error messages on CR1 router
Mar 13 01:05:28: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.1.1.2 (GigabitEthernet0/0.1) is down: retry limit exceeded
COnfiguration:
on my CR1 router
int gi0/0.1
encapsulation dot1Q 1 native
ip address 10.56.52.12 255.255.255.192
ip address 10.1.1.4 255.255.255.0 secondary
on CR2 router
int gi0/0.1
ip address 10.1.1.2 255.255.255.0
10.1.1.*/24 IP address configured on CR1 as secondary scope. is it causing the issue (EIGRP flaping continuously) ?
Thanks in Advance
Sri
Solved! Go to Solution.
03-12-2013 05:47 PM
Looking at this link
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a008012dac4.shtml#three
A. EIGRP does support secondary addresses. Since EIGRP always sources data packets from the primary address, Cisco recommends that you configure all routers on a particular subnet with primary addresses that belong to the same subnet. Routers do not form EIGRP neighbors over secondary networks. Therefore, if all of the primary IP addresses of routers do not agree, problems can arise with neighbor adjacencies.
So router CR1 CANNOT form an adjacency using its secondary address
Alex.
Please rate useful posts.
03-12-2013 05:47 PM
Alex.
03-12-2013 05:55 PM
Thanks Alex,
One more doubt.. then why neighbour is forming and teared off again and again? (or is it expected behaviour ?)
Mar 13 01:45:12: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.1.1.2 (GigabitEthernet0/0.1) is down: retry limit exceeded
Mar 13 01:45:15: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.1.1.2 (GigabitEthernet0/0.1) is up: new adjacency
Mar 13 01:46:35: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.1.1.2 (GigabitEthernet0/0.1) is down: retry limit exceeded
Mar 13 01:46:39: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.1.1.2 (GigabitEthernet0/0.1) is up: new adjacency
03-13-2013 06:00 AM
CR2 - Sends EIGRP HELLO to 224.0.0.10 Multicast ( Every 5 secs)
CR1 - Hears this packet and responds with the IP address from
its primary IP address
CR2 - Hears this respons BUT the Ip address from CR1 is not
in the correct Ip subnet
This process will keep repating till 16 attempts have
been tried
At this time CR2 will alert
with
Then the whole process starts again until you resolve the
fact that EIGRP neighbours CANNOT form on
IP secondary addresses.
Hope this helps
Alex.
03-13-2013 09:26 AM
Hello Alex,
I do understand the retry limit exceeded but why is the router showing this:
For me the router should see that the neighbor is on a different subnet that him and never say up.
I was wondering if you could clarify that to me,
Julio Carvajal
