EIGRP routing
one basic doubt
when i create a VLAN 172.16.30.0/24
generally i do the routing in EIGRP as network 172.16.0.0 so can we use network 172.16.30.0 0.0.0.255 in eigrp routing
karthik
3 Accepted Solutions
Nagaraja Thanthry
EIGRP supports VLSM. So, yes, you can use "network 172.16.30.0 0.0.0.255" statement. Please make sure that if you have different major networks on the router, you have disabled "auto-summary".
Hope this helps.
NT
Note: Please rate useful posts
eigrp in case of no wildcard mask , will consider classfull mask for that network segment which in your case is class b mask ( 255.255.0.0 ). so assigning a wildcard mask will make sure that Eigrp knows the exact vlsm subnet is attached to the interface.
hope it helps
manish
Ganesh Hariharan
one basic doubt
karthik
Hi Karthik,
EIGRP carries the subnet mask in the routing update, and it does support both variable length subnet masks (VLSM) and Classless Inter-Domain Routing (CIDR). In other words, you can subnet your network from the classful boundaries (where a class A network is 10.0.0.0 with a 255.0.0.0 subnet mask, etc.), and EIGRP will work fine.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
6 Replies 6
Nagaraja Thanthry
Hope this helps.
NT
hope it helps
manish
Thanks for the reply I got the needed information
Karthik G
Network Administrator
BHUSD
(310)-551-5100 x2357
Karthik G
Ganesh Hariharan
one basic doubt
karthik
Hi Karthik,
Hope to Help !!
Ganesh.H
Karthik G
BHUSD
