Embedded packet capture: 2960 LANBASE
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading.
The switch is running 15.0(2)SE6
I'm seeing 0 byte counts on my buffer.  The switch accepts these commands:
config terminal
ip access-list extended CAP-FILTER
   permit ip any any
   exit
exit
monitor capture buffer CAP-BUF max-size 7000
monitor capture buffer CAP-BUF filter access-list CAP-FILTER
monitor capture point ip cef CAP-POINT f0/29 both
monitor capture point associate CAP-POINT CAP-BUF
monitor capture point start CAP-POINT
Does this IOS need a local destination port?  There's 16MB free on the flash.  What am I doing wrong?
Thanks!
Bob
Reza Sharifi
Not sure if the 2960 series with lan base license support it but this link has sample config for the 3850 series that maybe helpful.
https://supportforums.cisco.com/document/12013221/using-3850-embedded-wireshark-wired
Reza Sharifi
