enable traps snmp linkdown linkup cannot work
wfqk
Level 5
Level 5
Hi, Anyone can take a look at the commands and snmp-server enable traps snmp linkdown linkup. I do not know why it cannot work. Do you think the configuration on it is correct? Please see the below
MySW(config)#do sh run | i snmp
snmp-server community TSHOOT RO
snmp-server location Amsterdam
snmp-server contact info@networ.com
snmp-server host 10.0.0.123 version 2c TSHOOT
The switch and PC(Solarwinds installed) can ping each other.  Ip address 10.0.0.123 is the PC ip address to connect to the switch. Solarwind can see the switch. But the issue is after several interfaces are shutdown in switch, why no any change can be seen on Solarwind side?
Reza Sharifi
Make sure that SolarWinds APM is monitoring all switch interfaces under the resource tab.
Reza Sharifi
Thanks for your reply. I cannot find APM on NPM page. Is APM another component of Solarwinds which needs to be installed?
Yes, NPM is a module and it is usually the main page most customers install.
Have a look:
http://www.solarwinds.com/network-performance-monitor
got it. Thank you!
