Enabling port security on C4507R shuts down port
japonte
I'm trying to enable port security on several 4507R's. When I try to configure a range of ports the switch will randomly put 1 or 2 in err-disable.  It's different every time I apply the config to the same group of ports.  However if I do them one at a time it seems to work.  But I really don't want to configure 6 fully populated switches one port at a time.   We also have a lot of 3750's and they gave me no problem using a port range.
Here is the config I'm trying to configure
switchport port-security
switchport port-security maximum 2
switchport port-security aging time 1
switchport port-security aging type inactivity
The IOS version is. 12.2(25)EWA8
Benjamin Kools
Try rearranging the order in which you put the commands in. Put "switchport port-security" in last, as immediately when you enter this command, port security is enabled with the default maximum of 1 mac address per interface. If a port has two hosts on it before the next command setting the maximum to 2 is entered, it will get disabled.
Another option is to temporarily enable error disable recovery:
errdisable recovery cause psecure-violation
errdisbale recovery interval 'seconds'
Benjamin Kools
Thanks.  I'll try that tonigh and let you know.
Make sure the ports you're trying to configure are access ports (switchport mode access).
That did the trick.  I put switchport port-security at the bottom and when I applied it to ranges no ports went int err-disable.
