Enabling SSH on edge switch C2960
farjad_feroz
Community Member
I am newbie in networking, I want to enable SSH, on the my edge switches model and SW image is given below
WS-C2960-24TT-L     C2960-LANBASE-M
WS-C2960-48PST-L    C2960-LANBASE-M
WS-C2960-48TC-L      C2960-LANBASEK9-M
Kindly refer me any configuration guide of cisco and ways to enable SSH since I came to know from a person that my switch model doesnt support SSH?
Thanks.
Farjad
3 Accepted Solutions
devils_advocate
Level 11
Level 11
The 2960 does support SSH but it depends on the IOS version you are running.
I think the K9 one above will do SSH but the other two probably won't.
You can check but typing #ip ssh ? in config mode and if you get 'Unrecognised Command' then it doesn't support it and you need to upgrade to an IOS which does.
cadet alain
you need a crypto image for SSH support(k9).
Alain
configuring ssh is simple:
crypto key generate rsa modulus 1024
ip ssh version 2
and you're done, thenyou'll have to configure a local user and on your vty lines:
either login local or nothing if you have aaa new-model + aaa authentication login default local
Alain
devils_advocate
Level 11
Level 11
Kindly refer me any configuration guide of CISCO for upgrading IOS and for enabling SSH in K9 images.
Thanks alot
cadet alain
Alain
ip ssh version 2
Alain
