Showing results forĀ
Search instead forĀ
Did you mean:Ā
encapsulation dot1q
nelba_aldovino
Hi All,
I have  a problem pinging the ip of the router when i configure encapsulation dot1q in its router fastethernet 0/1
here's the router configuration
Current configuration : 533 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 2
ip address 1.1.1.254 255.255.255.0
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line vty 0 4
login
end
below is the configuration of the switch where the router is connected
Building configuration...
Current configuration : 1328 bytes
version 12.1
hostname Switch
switchport mode trunk
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
switchport access vlan 2
switchport mode access
interface FastEthernet0/22
switchport access vlan 4
interface FastEthernet0/23
switchport access vlan 3
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
and here is the diagram.
all the pc can ping the core switch but if it pings the router it failed.
all vlan configuration are configured on the core switch.
here's the running config of the core switch
Current configuration : 1288 bytes
version 12.2
hostname Switch
ip routing
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 1.1.1.64 255.255.255.0
interface Vlan3
ip address 1.1.2.64 255.255.255.0
interface Vlan4
ip address 1.1.3.64 255.255.255.0
ip classless
line con 0
line vty 0 4
login
end
what must be wron on my configuration?
Please help!!!!
thanks,
nhel
Jon Marshall
Looking at the diagram fa0/24 is the uplink  to the router but you have fa0/24 configured as an access port ie.
if you only want vlan 2 on that link then your router config is wrong, ie. you do not need subinterfaces and you can just configuer the router as -
duplex auto
speed auto
and then remove the subinterface configuration.
If you want to actually have other vlans on this link and have mutliple subinterfaces on the router then you need to change the switchport config on your switch to -
int fa0/24
Not sure which one you actually want to do ?
Jon
  Also you need to determine who is going to do the routing for vlan 2  , the router or the switch .  It should not be in both places the way you have it now .
