Encapsulation for Catalyst 2960
chaney_jon
Replacing a 2900XL with a new 2960 and need to copy over some configs. I need to put switchport trunk encapsulation dot1q in int fas0/23 but "encapsulation" is not an option to enter. I can only enter allowed, native, or pruning.
I'd appreciate any help with this. Thanks.
It won't allow you to put the line:
It will reject it. If that's the only encapsulation type that switch supports, then that's the one it will use when you enter:
switchport mode trunk
5 Replies 5
ankbhasi
Hi Chaney,
2960 switch only supports dot1q encapsulation and that is the reason encapsulation command is not available/supported.
Ankur
*Pls rate helpfull post
Thanks for your reply. Just so I'm clear, if I'm copying these lines:
interface FastEthernet0/23
switchport access vlan 2
interface FastEthernet0/24
Would I just leave out the encapsulation line all together? Would there be something in its place (allowed, native, pruning)?
You do not need to enter "switchport trunk encapsulation dot1q". It is built into the IOS as this model only support dot1Q trunking.
You will need "switchport access vlan 2" and "switchport mode trunk" according to your need.
Shaheen
Thanks for the help everyone.
