Encrytion between two Cisco 1841 Routers
Tenek85466
Hi @all, I have the following topology. I wish to encrypt the traffic between both router in such a way that all data that goes from one side to another through the link stays encrypted @royalblues
Topo.PNGBG
2 Accepted Solutions
Reza Sharifi
On the router, you are not configuring the vlan access list. You just configure each IP segment that is associated with each vlan.
10 Replies 10
Reza Sharifi
You can use IPSEC if your IOS support security features. See link:
https://www.cisco.com/c/en/us/support/docs/routers/1700-series-modular-access-routers/71462-rtr-l2l-ipsec-split.html
Thank you very much! But how can I configure the access lists for every VLAN ?
as an alternative, you could also configure VTIs. Does the local traffic just have to go to the other side, or do you also need Internet access for your local Vlans ?
Hi! The local traffic goes to the other side and the local VLAN's already have internet through NAT und ISP.
what did you configure to resolve the problem of overlapping networks at each side ? Did you use policy NAT, or twice NAT ? Post the running configurations of both your 1841 routers...
Hi @Georg Pauwen! I used twice NAT on both Routers. For the VLANs I used "Router on Stick". The router interface directly connected to the switch just have sub-interfaces. Based on https://www.cisco.com/c/en/us/support/docs/routers/1700-series-modular-access-routers/71462-rtr-l2l-ipsec-split.html how should I write the ACL`s in other to encrypt the traffic between both routers?
Just for reference, can you post your final, working configs ?
Router1
hostname test
ip dhcp pool vlan30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.254
dns-server 192.168.134.8
ip cef
no ipv6 cef
crypto isakmp policy 10
hash md5
crypto isakmp key 01.020r address 192.168.133.44
crypto ipsec transform-set 01.020r esp-des esp-md5-hmac
crypto map 01.020r 10 ipsec-isakmp
set peer 192.168.133.44
set transform-set 01.020r
match address 100
ip ssh time-out 60
ip domain-name test.com
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.254 255.255.255.0
ip nat inside
interface FastEthernet0/1
ip address 192.168.133.17 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map 01.020r
interface Vlan1
no ip address
shutdown
ip nat pool 01.020r 192.168.133.17 192.168.133.17 netmask 255.255.255.0
ip nat inside source list 10 pool 01.020r overload
ip classless
ip flow-export version 9
access-list 10 permit 192.168.30.0 0.0.0.255
access-list 100 permit ip 192.168.30.0 0.0.0.255 192.168.30.0 0.0.0.255
banner motd ^C
ex
^C
line con 0
line aux 0
line vty 0 4
login
end
Router2
Current configuration : 1338 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp pool vlan30
ip cef
no ipv6 cef
hash md5
authentication pre-share
crypto isakmp key 06.010r address 192.168.133.17
crypto ipsec transform-set 06.010r esp-des esp-md5-hmac
crypto map 06.010r 10 ipsec-isakmp
set peer 192.168.133.17
set transform-set 06.010r
match address 100
no ip address
duplex auto
speed auto
ip nat inside
ip address 192.168.133.44 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map 06.010r
interface Vlan1
no ip address
shutdown
ip nat pool 06.010r 192.168.133.44 192.168.133.44 netmask 255.255.255.0
ip nat inside source list 10 pool 06.010r overload
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Joseph W. Doherty
BTW, if you encrypt the link, your logical MTU may shrink. If it does, don't overlook the issue of possible packet fragmentation.
