ePagp between two VSS systems
krahmani323
Participant
Participant
Hello community,
I have never implemented ePagp between two VSS systems and would like to be know there is no restriction about such implementation.
After going through the different documents I see ePaGP is well supported (
krahmani323
Participant
Participant
Edit :
Hello community,
I  have never implemented ePagp between two VSS systems (different domain IDs of course) and would like to  know if there is some restriction about such implementation.
After going through the different documents I see ePaGP is well supported with 6500 neighbors since 12.2(33)SXH and just wanted to be sure there if is no restriction or any side effect to implement it on both sides of the VSS MEC.
Does someone has implemented it in his environment and is it working just like other epagp compatible neighbors ?
Thanks a lot!
Karim
