errdisable recovery
In 6500 and access switch, please let know the best practice for errdisable recovery.
We had configured two 6500, for testing when we try to Switch off the active SW and again SW on the same switch all the uplink in the core switch come to errdisable. Please advice.
5 Replies 5
Leo Laohoo
VIP Community Legend VIP Community Legend
There is none.  Try to minimize or refrain from using "errdisable recovery" option.  This is even more important when used on a chassis-based system like the 6500/6800 and/or 4500 systems.
If the ports went into error-disable this means something is wrong and is worth investigating.  To use "errdisable recovery" is akin to sweeping a potential problem under the carpet and is not a good practice.  This option only works well in a lab environment.
Please advice more info or steps on how to investigating why the switches goes to err-disable state ?
Command:  sh interface status err
Your question is not very clear.  Can you explain in details what are you testing and what you are trying to do?
dgomez2
I find a doc that can help you.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/24330-185.html#cg7
This document talk about many BP for 6500.
Regards.
Recognize Your Peers
