Error de power supply en stack
gastontolosa
Buenos días, estoy teniendo un problema con los modulos de las fuentes redundantes de un stack de Catalyst 9300. Les dejo los detalles, no tengo fuente B instalada
PLATFORM_FEP-1-FRU_PS_ACCESS: Switch 1: power supply B is not responding
PLATFORM_FEP-1-FRU_PS_ACCESS: Switch 2: power supply B is not responding
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C1-715WAC LIT222927AP OK Good Good 715
1B Unknown Unknown No Input Power Bad Bad Unknown
2A PWR-C1-715WAC LIT22285HXR OK Good Good 715
2B Unknown Unknown No Input Power Bad Bad Unknown
Switch Ports Model SW Version SW Image Mode
* 1 65 C9300-48P 17.06.04 CAT9K_IOSXE INSTALL
2 65 C9300-48P 17.06.04 CAT9K_IOSXE INSTALL
Agradezco por su ayuda.
Reza Sharifi
Do you have a second PSU in each switch? If you do, is the power connected to each PSU? As you can see below, it says "no input power"
Hi, no i don´t have a second PSU.
OK, so that basically says, you don't have a second PSU installed in each switch.
Yes, but thats the problem, i have a monitoring system and it reports that the switch its down because of this. The switch doesn´t show that doesn´t have a PSU, it has an unknown condition on the B slot.
