Hello all
I have one 2921, with HWIC-D-9ESW, and I am seeing this error on logs:
esw_dtc_ltc4258_reg_write : s2w timed out on unit 0 reg 0x18 data 0x22
S2W Error IIR 0x0006 ISR 0x8000
esw_dtc_ltc4258_reg_write : s2w timed out on unit 0 reg 0x18 data 0x44
esw_dtc_ltc4258_reg_write : s2w timed out on unit 0 reg 0x18 data 0x88
Even it is working normaly, anyone have an idea of what can be causing this messages?
The router version:
RT_WAN_VICT#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
RT_WAN_VICT uptime is 15 weeks, 5 days, 57 minutes
System returned to ROM by bus error at PC 0x22644EB4, address 0x182BB3A5 at 15:20:25 WAT Thu Apr 23 2015
System restarted at 15:21:57 WAT Thu Apr 23 2015
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FGL164710K4
9 FastEthernet interfaces
3 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
1 Services Module (SM) with Services Ready Engine (SRE)
Cisco Wide Area Application Services Software 4.4.3 (b4 Aug 22 2011 10:22:29) in slot/sub-slot 1/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
