Error loading flash on 2950 switch
mahesh18
Level 6
Level 6
hi all,
i did write erase and  then did delete flash:vlan.dat  after that i reloaded
when switch was booting up i get error
Error loading "flash:/c2950-i6k2l2q4-mz.121-22.EA8a.bin"
after this message switch booted ok
here is sh flash   and  other info
Switch#verify ?
  /ios    Verify compressed IOS image checksum
  /md5    Compute an md5 signature for a file
  flash:  File to be verified
Switch#verify flash:/c2950-i6k2l2q4-mz.121-22.EA8a.bin
%Error verifying flash:/c2950-i6k2l2q4-mz.121-22.EA8a.bin (No such file or direc
tory)
Switch#sh flash:
Directory of flash:/
    2  -rwx     3721946  Mar 01 1993 00:31:57 +00:00  c2950-i6k2l2q4-mz.121-22.E
A13.bin
    7  -rwx         316  Oct 28 1993 05:57:54 +00:00  env_vars
   21  -rwx         109  Mar 01 1993 00:04:19 +00:00  info
   22  -rwx         109  Mar 01 1993 00:04:19 +00:00  info.ver
7741440 bytes total (4016640 bytes free)
my question is is everything ok with my switch?????????
many thanks
mahesh
Jon Marshall
mahesh18 wrote:
hi all,
Switch#sh flash:
A13.bin
many thanks
mahesh
Mahesh
Your switch is trying to boot an image that isn't there. Perhaps you had a boot system ... statement in your running-config that pointed to EA13 image but when you deleted the running-config it fell back to the bootvar ?
Your switch is fine but i would suggest -
1) do a "sh version" and make sure the switch is using the EA13 image
2) add this to your config -
   switch(config)# boot system flash flash:/c2950-i6k2l2q4-mz.121-22.EA13.bin
save the config and reload the switch and see if you still get the same error message.
Jon
Jon Marshall
mahesh18 wrote:
hi all,
Switch#sh flash:
A13.bin
many thanks
mahesh
Mahesh
Jon
Hi jon
I did exactly as you said and error is gone now.
Many thanks
best regards
mahesh
