Error Messages and Performance Issue Switch 6509
rpastrana
Hello, we have a chassis 6509 with this inventory:
------------------ show module ------------------
Mod Ports Card Type                                              Model
  1   48      CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  3   48      CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  5    2       Supervisor Engine 720 (Active)                 WS-SUP720-3B
  9   48      CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
Mod       Hw       Fw           Sw           Status
  1      2.5   12.2(14r)S5    12.2(33)SXH8 Ok
  3      2.5   12.2(14r)S5    12.2(33)SXH8 Ok
  5      5.3    8.4(2)            12.2(33)SXH8 Ok
  9      3.0   12.2(18r)S1    12.2(33)SXH8 Ok
Mod  Sub-Module                      Model                     Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       3.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       3.1    Ok
  5  Policy Feature Card 3          WS-F6K-PFC3B      2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720           2.6    Ok
  9  Distributed Forwarding Card  WS-F6700-DFC3B   4.7    Ok
And we're getting syslog error messages spamming from Modules 3 and 5.
Feb 20 01:50:45: %CONST_DIAG-SP-4-ERROR_COUNTER_WARNING: Module 3 Error counter exceeds threshold, system operation continue.
Feb 20 01:50:45: %CONST_DIAG-SP-4-ERROR_COUNTER_DATA: ID:48 IN:0 PO:255 RE:576 RM:255 DV:3 EG:2 CF:10 TF:64
Feb 20 01:50:45: %CONST_DIAG-SP-4-ERROR_COUNTER_WARNING: Module 5 Error counter exceeds threshold, system operation continue.
Feb 20 01:50:45: %CONST_DIAG-SP-4-ERROR_COUNTER_DATA: ID:48 IN:0 PO:255 RE:578 RM:255 DV:4 EG:2 CF:10 TF:1336
I've read a few posts around about these messages being caused by:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00801b42bf.shtml#module
*The module has to be reseated right.
OR
*The module is faulty.
Needed some opinions about this case since it was kind of weird.
Apart from that, I'd like to know if these modules are in the right slot for each of them, I've checked them in cisco site, but still needed a few more opinions about it, it's something I'd like to confirm somehow.
Kind regards.
6 Replies 6
InayathUlla Sharieff
Could you please provide me the following outputs;
show version
Show module
Show diagnostic result module 3 & 5
Inayath
Hello, thank you for the reply, the show module is in the first post, forgot to attach also this:
Mod  Online Diag Status
  1  Pass
  3  Pass
  5  Pass
  9  Pass
Now this is the show diagnostic for module 3 and 5.
https://dl.dropbox.com/u/10240910/show%20diagnostic.txt
Kind regards.
HI,
Whats the firmware version running on this device?
Inayath
Hello, this is the FW and SW for each module.
Mod       Hw       Fw           Sw           Status
Kind regards.
I researched it there is no issue with the firmware.
Kindly follow the recommendation suggested in the link which you mentioend and collect the below ouptut:
Here are the steps for setting the diagnostic level to complete and reseating the module :
1.            Switch(config)#diagnostic bootup level complete
2.            Switch(config)#end
3.            Switch#write memory
4.            Switch(config)# No power enable module
5.            Physically pull out and reseat the module firmly in the chassis to hard-reset the module.
6.            Switch(config)# power enable module
If still it throws the error then we have to replace the module.
There is an workaround to avoid this error:
Disable the test with the command
(config)#no diagnostic monitor module 3 test TestErrorCounterMonitor
Inayath
*Plz rate the usefull posts.
Thanks! I will try it out!
