ES+ LLQ elastic QoS -- Policing
Dears
Would like your assistance please regarding ES+ LLQ QoS
As you know with SIP cards, when you configure LLQ you don't need to configure policing with priority command. So behavior in case of congestion that LLQ voice packets will only get their assigned BW however when there is no congestion, LLQ voice packets can exceed their assigned BW.
With ES+ configuration is not accepted till you configure policing command. So this means even in case of no congestion LLQ  voice can not exceed their assigned BW
Now question, is there a way to have elastic LLQ style as that of SIP cards ?
Many Thanks
Sherif Ismail
pille1234
Level 3
Level 3
Hi Sherif Ismail,
as some time has passed without any answer, have you found a solution in between? I'm having the same problem and I fear there is no workaround available.
Pille
Hi Pille
Unfortunately no !
Sherif Ismail
