145
Beginner
ES3G-24-P Recovery
I have a ES3G-24-P that i inadvertently loaded an unsupported switch image on, now when it boots it gets stuck in a loop and keeps trying to reload the failed IOS.  Is there a way to stop the boot process and get the module in rommon mode so i can point it to the correct boot image which is still in flash?  It is installed in a 2911.  Any help is greatly appreciated.  Thanks.
1 ACCEPTED SOLUTION
VIP Expert
Re: ES3G-24-P Recovery
Try following this document using password recovery section:
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#pgfId-1931266
1 REPLY 1
VIP Expert
Content for Community-Ad
July's Community Spotlight Awards
