Ether-channel between Catalyst 4500 and Nexus switch
I have a 2 core switch catalyst 4500 connected to Nexus switch by Ether-channel and the gateways for VLANs created on the Nexus switch
now the end-user which connected at Catalyst 4500 can`t access to other users at other VLANs and also can`t  ping  their VLAN gateway
I don`t have access to the Nexus switch, only Catalyst, so if any show commands from Catalyst 4500 side can help me to troubleshoot this issue or at least tell me where the problem and if the configuration from my side is correct
the o/p of sh run
interface Port-channel6
description #Connected to nexus#
switchport
switchport mode trunk
interface TenGigabitEthernet1/2/3
description #Connected to Leaf 101 - e1/5#
channel-group 6 mode on
interface TenGigabitEthernet1/2/4
description #Connected to Leaf 102 - e1/5#
interface TenGigabitEthernet2/2/3
description #Connected to Leaf 101 - e1/6#
interface TenGigabitEthernet2/2/4
description #Connected to Leaf 102 - e1/6#
omz
Check Nexus port-channel mode is also set to on.
Correct vlans are allowed over the trunk.
Catalyst -
sh etherchannel summary
sh interface trunk
Nexus -
sh port-channel summary
sh interface trunk
Hello
Is the port-channel up
sh etherchannel-port-channel
sh int trunk
Kind Regards
Paul
