Etherchannel behaviour
acarlos.pinheiro
Community Member
I am studying for 642-813 switching exam and I faced the following doubt:
From the book CCNP SWITCH OFFICIAL CERTIFICATION GUIDE it is said that PAgP dynamically modifies parameters of the EtherChannel if
one of the bundled ports is modified:
"PAgP forms an EtherChannel only on ports that are configured for either identical static
VLANs or trunking. PAgP also dynamically modifies parameters of the EtherChannel if
one of the bundled ports is modified. For example, if the configured VLAN, speed, or duplex
mode of a port in an established bundle is changed, PAgP reconfigures that parameter
for all ports in the bundle".
And From the Cisco webpage it is said that if you change parameters in the port-channel then it is applied to all ports in the bundle.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swethchl.html
"After you configure an EtherChannel, configuration changes applied to the port-channel interface apply to all the physical
interfaces assigned to the port-channel interface. Configuration changes applied to the physical interface affect only the
interface where you apply the configuration. To change the parameters of all ports in an EtherChannel, apply configuration
commands to the port-channel interface, for example, Spanning Tree Protocol (STP) commands or commands to configure a Layer 2
EtherChannel as a trunk".
Are both of them correct?
Antonio
Hello Mike,
Well, I've performed an experiment and here are the results - posting as captured:
Sw2(config-if)#do show ether sum
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         PAgP      Fa0/11(P)   Fa0/12(P)
Sw2(config-if)#do show run int po1
Building configuration...
Current configuration : 92 bytes
interface Port-channel1
switchport mode trunk
end
Sw2(config-if)#do show run int fa0/11
Current configuration : 127 bytes
interface FastEthernet0/11
channel-group 1 mode desirable
end
Sw2(config-if)#do show run int fa0/12
interface FastEthernet0/12
end
Sw2(config-if)#int fa0/12
Sw2(config-if)#sw mo ac
Sw2(config-if)#
*Mar  2 05:33:28.508: %EC-5-CANNOT_BUNDLE2: Fa0/12 is not compatible with Fa0/11 and will be suspended (dtp mode of Fa0/12 is off, Fa0/11 is on)
*Mar  2 05:33:29.506: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/12, changed state to down
Sw2(config-if)#
end
Current configuration : 128 bytes
switchport mode access
end
Sw2(config-if)#sw mo tr
Sw2(config-if)#
*Mar  2 05:34:11.482: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/12, changed state to up
Sw2(config-if)#
Sw2(config-if)#
        d - default port
Sw2(config-if)#speed 10
Sw2(config-if)#
*Mar  2 05:34:34.132: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/12, changed state to down
*Mar  2 05:34:37.974: %EC-5-CANNOT_BUNDLE2: Fa0/12 is not compatible with Fa0/11 and will be suspended (speed of Fa0/12 is 10M, Fa0/11 is 100M)
Sw2(config-if)#
        d - default port
1      Po1(SU)         PAgP      Fa0/11(P)   Fa0/12(s)
end
Current configuration : 137 bytes
speed 10
end
Sw2(config-if)#
Note that at first, I had a working PAgP-controlled EtherChannel on logical interface Po1 bundling together Fa0/11 and Fa0/12. Then, on Fa0/12, I've changed the mode from trunk to access. The switch merely complained that the port is incompatible and kicked it off the EtherChannel. As I show in subsequent commands, the Fa0/11 did not inherit the switchport mode access command even though PAgP was running and I entered this command on Fa0/12.
Afterwards, I have put Fa0/12 back to trunk mode and instead, I've reconfigured it statically to 10Mbps. Again, the switch complained and suspended the Fa0/12, claiming that Fa0/11 is running on different speed. And just as before, the setting of speed 100 was not carried over to Fa0/11.
So I believe that the book is not entirely correct on what it says. Perhaps the author is confusing PAgP and EtherChannel in general. However, I see no logical reason why should PAgP try to "equalize" the local configuration of physical ports. It can be done easily by always configuring the logical Port-channel interface, so why should PAgP duplicate this work.
PAgP and LACP are intended to negotiate whether ports can be used as a single EtherChannel on both interconnected devices, but apart from that, I don't ever recall seeing or reading anything that would go beyond this signalling/negotiating function.
Best regards,
Peter
6 Replies 6
burleyman
Level 11
Level 11
I think the Cisco link you give is talking about LACP etherchannels and then it goes on to talk about understanding PaGP etherchannels. The one from the book is talking about PaGP. So yes they are both correct. PaGP change one port they all dynamicly change. LACP change one port and it only affects that port.
Mike
Hello Antonio and Mike,
I believe there is a misunderstanding here.
Neither LACP nor PAgP are going to modify the configuration of the ports on the opposite device. At most, they can compare a selected set of configuration parameters but to my best knowledge, they do not actually cause the neighboring switch to reconfigure itself.
Regarding the automatic reconfiguration of local ports - I think that this is related to the fact that every configuration performed on the Port-channel interface is automatically pushed down by IOS to all physical member ports. There is, however, no PAgP or LACP involved here. The same would be true even for mode on EtherChannels where none of these two protocols is used.
Please feel welcome to disagree and debate this!
Best regards,
Peter
No I did not mean the opposite device....just on the same device. I also agree about changing the port channel and it pushing it to the individual ports. I think what he was asking based on the info he provided was that the two things seemed to be contradicting. What I was saying is, on the same switch, if you are setup using PaGP and you change the port config it will dynamicly change all the other ports in the channel. If it is LACP if you make a change to the individual port it will only apply to that one port and not all the other ports in the channel.
Please correct me if I am mistaken. But that is what I got out of reading the two things mentioned. Peter I will rely on you to set me straight.
Mike
Hello Mike,
        d - default port
end
end
end
Sw2(config-if)#
Sw2(config-if)#
end
end
Sw2(config-if)#
Sw2(config-if)#
Sw2(config-if)#
        d - default port
Sw2(config-if)#
Sw2(config-if)#
        d - default port
end
speed 10
end
Sw2(config-if)#
Best regards,
Peter
Peter...thanks for the information. 5+
I was just going by the book and the Cisco website. It does appear the book is not correct. I think I will email him and see what exactly he was trying to say.
Peter, thank you as always.
Mike
acarlos.pinheiro
Community Member
Well Folks, many thanks for helping me clarify this doubt.
Antonio
