Etherchannel between two vtp domain
ccitob2014
I have two switches 6509 one switch is confire with VTP domain ABC Other switch is configure with ABZ, At present the switch is configure with the L3 interface and one fiber cable is connected between two switches.
I want to remove L3 configuration wants to make L2 etherchannel and wants to ceraeate Loop back will assing same ip both side.
The OSPF is configure both side , i will not do any changes in the OSPF as L3 ip is advertise in OSPF.
Please kindly Advise.
Reza Sharifi
No clear what you are trying to do here, but you can't assign the same loopback address to both switches unless they are configured as VSS.
