etherchannel between WS-C4506-E and stacked WS-C2960S-48LPS-L
we are having a "suspend" issue to portchannels with 2960S switches only.
On our core switch we have the following setup:
interface Port-channel68
 description EC DELEJ02SAC88
 switchport
 switchport trunk allowed vlan 6,7,10-12,19-21,30,63
 switchport mode trunk
and the two ports are:
interface GigabitEthernet1/3/10
 description SAC88
 logging event link-status
 udld port aggressive
 channel-group 68 mode active
interface GigabitEthernet2/3/10
 description ECM DELEJ02SAC88-D20
On the other end we have a stacked 2960s with two switches.
Ports are configured as this:
interface Port-channel1
 description Uplink Core
 switchport trunk allowed vlan 6,7,19,21
and the two stack ports (one of each switch):
interface GigabitEthernet1/0/49
 description Uplink Core/Chassis1
 mls qos trust dscp
 channel-group 1 mode active
and
interface GigabitEthernet2/0/49
 description Uplink Core/Chassis2
 mls qos trust dscp
Same configuration we do have on our not stacked 2960 and is working fine. But here we have one port in supended state:
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi1/0/49(P) Gi2/0/49(s)
We don't have anything in the logs.
Do anybody came across with this issue or having nay idea how to fix it?
Many thanks in advance
@Lex
glen.grant
   Verify your ports are correct , you have different descr on the 4500 on the ports so i would verify they go where you think.  Trace them and or use CDP to verify they go where you think .  Config looks ok though i would match the allowed vlans on both sides to keep it consistent.  Look in the logs also , it usually gives an indication why it is suspending the ports.
Filip Po
I met similiar problem on C4500.
Try to remove etherchannel configuration by taking ports to it's defaults and also interface Port-channel68.
Then create port channel interface by first issuing :
 description SAC88
Then configure all stuff around switchport under interface Port-channel68.
Hi guys,
thanks for quick respond. CDP neigh allready checked, connected to the right ports.
I will try removing / adding port channel on core but have to wait getting a time window from site.
THX
Did you get it worked?
