Cisco Community Designated VIP Class of 2020
4115
Beginner
etherchannel fail to work after one of the port is down
Hi all,
I did a test to configure a etherchannel using port23 and port24 on 2 switches to connect them together. I tested connectivity between devices connected on different switch and it works fine. However if i shut down either port 23 or port24 on 1 switch, connectivity between the switches fail to work. This shldnt be the case since i have the other port in my etherchannel. Pls advise. Thks in advance. below is my config
Current configuration : 2155 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport access vlan 3
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
channel-group 1 mode on
switchport mode trunk
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Port-channel 1
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Everyone's tags (5)
6 REPLIES 6
Rising star
What model switch is this? When the EtherChannel is functioning correctly can you post the output of 'show etherchannel summary' ?
Beginner
I am using 2960. SHow etherchannel summary as below for both switches. Thk you!
Switch#show etherchannel sum
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)           LACP   Fa0/23(P) Fa0/24(D)
Beginner
Just to add, i try changing channel-group mode to active, shut dwn 1 port and still it doesnt work. THere are 2 vlans running across the etherchannel and only 1 vlan could work and not the other
Rising star
From looking at that configuration, I would assume that the default of all vlans are allowed over that trunk as far as those interfaces are concerned. Look at the configuration of each switch and verify that the appropriate vlans allowed to travel over each trunk port. Also, you have several different types of EtherChannels.
LACP - Open Standard
PAgP - Cisco Proprietary
Static - Always on
With LACP- you will need to either have 'channel-group 1 mode active' and the other side will need to be either 'active as well or passive'.
With PAgP - You will need to either have 'channel-group 1 mode desirable' and the other side will need to be auto and or desirable as well. You cannot have auto on one end and auto on the other end, the EtherChannel will not come up.
Static - You will need configured as 'channel-group 1 mode on' on both ends. This is statically set and does not dynamically setup an etherchannel.
Generally, the number used after channel-group doesn't matter, but in older switches it will need to be the same. I would make them the same anyone just for better clarification on what goes where.
Rising star
Re: etherchannel fail to work after one of the port is down
        d - default port
here from the output, i can see your Po1 is UP > (SU) !
anyway, if you are experiencing problems, remove the portchannel interface which is already there. then try to explicitly configure the parameters that you need to be there on ur member interfaces. lets say;
int f0/23  & int f0/24
switchport trunk allowed vlan .... (optional)
then, shut down the po1 (newly created) on both switches and bring them back up.
see if it works fine.
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
Advisor
   Your display shows one port being down before you even start . Do both ports show connected  when you do a show int status ?    Between cisco devices use  a negotiated etherchannel either lacp or pagp .  This is for pagp. When bringing the port channel up do a no shut on the port channel SVI so that both ports come active at the same time .
int x/23
switchport trunk native vlan X --  must match on both sides
switchport trunk allowed vlan x
channel-group 5  mode desirable non-silent
int x/24
int port-channel 5
switchport trunk native vlan x
no shut
Content for Community-Ad
