etherchannel issue
after1111
I've configured etherchannel on my switch but i can only ping the default vlan 200, but not other VLANs. This is a layer 3 switch - routing is enabled.
Any ideas?
interface Port-channel1
switchport trunk native vlan 200
switchport trunk allowed vlan 300,400,500
switchport mode trunk
interface GigabitEthernet1/0/1
channel-group 1 mode on
interface GigabitEthernet1/0/2
end
switch1#show etherchannel summary
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi1/0/1(P) Gi1/0/2 (P)
motorola#show etherchannel detail
                Channel-group listing:
I noticed the protocol does not show (is this normal?). Im running LACP between the switch and the Dell server.
Ganesh Hariharan
Any ideas?
end
You have configured ether channel between switch port and server NIC ? and in your switch side you have configured on mode for etherchannel that whay protocol isnot showing in summary command.
which vlan is server is placed ?
Hope to Help !!
Ganesh.H
glen.grant
    You are not running LACP if you have the port channel set as on .  It would have to read "channel-group X mode active or auto "  to be using LACP.
