Etherchannel with modules performing different load balancing mechanism.
k.vlachoulis
I would like to ask if someone has ever configured an etherchannel that interfaces resides on different cards with different per module load balancing mechanism. We are planning to have such a case as we will implement MGSCP solution that requires for egress traffic per source ip load balance and for ingress per destination ip load balance. The existing devices hold an etherchannel that the interfaces that it bundles are connected to different modules.
7600-1 module 1 int g1/1 ------7600-2 module 1 int g1/1
7600-1 module 3 int g3/1 ------7600-2 module 3 int g3/1
We are planning to change the load balancing mechanism on module 1 per source ip and for module 3 per destination ip. Will this change result something bad to the existing operation of the port-channel? The only thing that i can think is some underutilized links.
BR
Kanellos
Peter Paluch
Hello Kanellos,
I do not have any first-hand experience with this setup. Are you sure that your 7600 actually allows you to set different load balancing methods for each card individually? Recalling the way it works on 3750 Catalysts, if you configure a particular load balancing method, it influences the entire switch stack. Have you actually tried implementing this kind of setup?
Best regards,
Peter
Hi Peter,
The per module load balance can be achieved if each module has its own DFC card.
Best Regards
Kanellos
