EtherChannel
oneirishpollack
So when you have redundant trunk links between swithes, and STP had blocked one ports of the links, it is a waste of resources NOT to use EtherChannel. Is this correct? EtherChannel allows you to aggregate the bandwidth of the two links, so in effect, we get more data from one switch to the other. Correct?
5 Replies 5
Richard Burts
Yes with Etherchannel the Spanning Tree sees only a single entity and all of the links within the Etherchannel are active and carrying traffic with none of them blocked by Spanning Tree.
Rick
Rick
Joseph W. Doherty
Richard already answered your primary question, but BTW, although EtherChannel provides more bandwidth between devices, it's not the same as having a single link with that bandwidth. Reason being, EtherChannel statically "hashes" traffic between its links. I.e. one link can be at 100% while others at 0%.
Hi Joseph
That really depends on the load sharing algorithm you have in use on the Port-Channel. The 6500's can use port as an option which allows quite fine LB of connections.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Adam,
EtherChannel load sharing algorithm is very important, since a poor choice (or lack of [equipment] choice) can lead to the situtation I described happening all the time, but even the best possible choice doesn't guarantee it won't happen.
The Achilles' heel (as far as I know) is one flow is always limited to one link. LB to link is always deterministic and doesn't respond to actual utilization.
Only reason I mentioned the issue at all (edit - especially in this particular forum topic), some might initially think EtherChannel always provides x*links improved performance.
However, I'm not trying to advance a "why not" but instead, a better understanding of the technology (which your reference will also provide).
Leo Laohoo
I don't know if this is relevant for this topic, but, coming soon to the nearest Cisco 6500/7600 series of switches near you ...
Virtual PortChannels: Building Networks without Spanning Tree Protocol
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/white_paper_c11-516396.html
