etherchannel?
alsayed
Hi!
is etherchannel works on different media & Different module?
e.g:Same speed?
Jon Marshall
Hi Ali
Yes Etherchannel will work with different media ie you can form an etherchannel with fibre and rj45 connections.
And yes you can create an etherchannel with ports from different modules.
See attached for Etherchannel guidelines and restrictions:-
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e6d3.html#wp1020420
Jon
HI Jon!
10XS FOR UR KIND REPLY...
