etherchannelconfig
Arvind kumar
                    Iam looking for some clarification regarding etherchannel, I need to add some vlans on an etherchannel allowed vlan list,
1. should this be done on the port channel configuration and not on physical interfaces as things get replicated down the physical interfaces.
2. does the vlans should exist on the switches if they are allowed on etherchannel interface. whats the issue if this doesn't exist.
3. should the allowed vlan list on the etherchannel can have different set of vlans on two switches etherchannel config which are between two switches.
Thanks in Advance.
Reza Sharifi
That is correct.  You add the allowed vlans to etherchannel and not the physical interfaces.
If the vlans exist, than they will be allowed.
Usually you want the same vlan on both sides of the portchannel.  If a vlan is not added on one side then it will not be allowed (just that one vlan).
