Ethernet up-link connection to an SFP up-link (two switches)
alexanderz2000
Beginner
Beginner
Hello all,
I'm a bit new to switches with Ethernet uplinks 10/100/1000 vs. SFP uplinks (specifically copper/rj45 SFP).
I need to connect two switches together so i can extend my second switch to another cage, i need to use the uplinks to do this but i have two different switches and i'm not sure if this will work.
Can I connect Sw A (C2960-48TT-L) with the Ethernet up-links 10/100/1000 to Sw B (2960S-48TS-L) with SFP copper (rj45) uplinks together?  I believe as long as both sides are set at 1000, I think it should be fine, correct?
I understand the 2960 is 48 port 10/100 vs the 2960s 48 port 10/100/1000 but i need gigabit on the extended cage for now, later I'll replaced the primary.
Please advise.
balaji.bandi
VIP Community Legend VIP Community Legend
you can extend the Copper as long as they do not go beyond Copper limitation.
BB
balaji.bandi
BB
Thank you so much!  i'm only going 20 feet which is under the limitations.
