EVN design - route replication
I am working the EVN design  but i am facing problem in the route replication (router leaking in VRF). I also read some cisco docs but did not get the
result.
Kindly look at below config and correct if there is any improper config
any example for EVN is helpful
vrf definition green
vnet tag 20
rd 2:2
address-family ipv4
  route-replicate from vrf red unicast ospf 10
exit-address-family
vrf definition red
vnet tag 10
rd 1:1
address-family ipv4
  route-replicate from vrf green unicast ospf 20
exit-address-family
interface Vlan10
vrf forwarding red
ip address 192.168.10.1 255.255.255.0
end
interface Vlan20
vrf forwarding green
ip address 192.168.20.1 255.255.255.0
end
router ospf 10 vrf red
network 192.168.10.0 0.0.0.255 area 0
router ospf 20 vrf green
network 192.168.20.0 0.0.0.255 area 0
Reza Sharifi
Try following the config guide.  it has examples:
http://www.cisco.com/en/US/docs/ios-xml/ios/evn/configuration/xe-3s/evn-overview.html
Thanks for reply Reza
I am looking for any document which explain Route Replication. The above document is introduction of EVN with some initial commands.
Fazal
I edited the config.....to make it simple...
Any solution on it.
