10-04-2020 11:32 PM
I have the below output can anyone help me in explaining the same.
Interface Speed Local pair Pair length Remote pair Pair status
Gi0/9 1000M Pair A 147 +/- 4 meters Pair A Normal
Pair B 150 +/- 4 meters Pair B Normal
Pair C 145 +/- 4 meters Pair C Normal
Pair D 145 +/- 4 meters Pair D Normal
10-05-2020 12:04 AM
As per the output all good - Normal means good, we need to worry if only Open.
here is good explanation :
10-05-2020 12:14 AM
Can pair length create some issue?
10-05-2020 01:05 AM
we are not sure what cable used, so i suggest to look this document length support by cat cable based on category :
https://www.digitaltrends.com/computing/different-types-of-ethernet-cables-explained/
by the way what is the model of the switch and end device ? what IOS running ?
10-05-2020 01:24 AM
The cable used is CAT6.
And below are the other details -
Switch Ports Model SW Version SW Image
* 1 24 WS-C2960G-24TC-L 12.2(25)SEE2 C2960-LANBASE-M
10-05-2020 01:58 AM
I would be using a more recent IOS.
I suspect the output to the cable length is a bug.
10-05-2020 09:39 AM - edited 10-05-2020 09:44 AM
No, as long as length is within margin of error , +/- 4 meters, your results look OK. The Length is not precise measurement when done with switch tdr. If you had bigger value discrepancies in length, then you worry about it.
10-05-2020 12:19 AM - edited 10-05-2020 12:24 AM
@abhiamoli wrote:Interface Speed Local pair Pair length Remote pair Pair status --------- ----- ---------- ------------------ ----------- -------------------- Gi0/9 1000M Pair A 147 +/- 4 meters Pair A Normal Pair B 150 +/- 4 meters Pair B Normal Pair C 145 +/- 4 meters Pair C Normal Pair D 145 +/- 4 meters Pair D Normal
What firmware is the switch running on? I am thinking this could be a 2960G or a 3560G?
