extended ACL block telnet visit
dannan lin
hi:
i have a scenario like above.  i wanted to allow R1 telnet R3, but R3 couldn't telnet R1.
i put an acl on f0/1 of R2 with "in" direction.
    10 permit tcp host 2.2.2.2 host 1.1.1.1 established
it worked, however it didn't work if i used following acl
           10 permit tcp host 2.2.2.2 host 1.1.1.1 eq telnet established
above acl will block telnet from both sides.
i think the problem lies with "telnet", but what caused this ? isn't telnet a part of tcp protocol suit (port 23)  ?
Your help is much appreciated.
have a nice day.
Richard Burts
The way that you have made the access list entry telnet would be the destination port. But when R3 sends response to R1 then telnet will be the source port. I think that your original access list is ok but if you want to make it more specific then try this version
permit tcp host 2.2.2.2 eq telnet  host 1.1.1.1 established
Rick
Rick
Richard Burts
Rick
Rick
thanks Richard, it worked, but i have an additional question .what if i still want my eigrp hello packets to pass through, in other words i still want to keep my routing table. i cannot use another  permit statements can i ?
thanks for spending your valueable time on such simple questions.
You can allow eigrp through in your acl:
permit eigrp any any
HTH,
John
HTH, John *** Please rate all useful posts ***
thanks richards.
