04-20-2020 05:14 AM
Hello everyone,
Im plannig to deploy a stack of cisco catalyst on my client site, those switches will be connected with 2 black fiber.
i created a vlan fot interconnection the firewall on my datacenter and the firewall on the client side, my questions are:
It's possible de do it over black fiber like on the picture ? if yes how vpc is ok ?
the interconnection vlan can be trunked to the cisco stack or i can create the vlan on on the nexus switches and configure the ports on access mode for connection the catalyst?
How can i avoid spanning tree loops to impact my cisco nexus 5K ?
If a loop happend on the cisco catalyst stack it can impact my nexus ?
can configure it to fail over instead of load balancing ?
Thank you in advance for your help
Solved! Go to Solution.
04-20-2020 09:10 AM
That's ok. If your Nexus switches are not root, do not enable peer-switch. The STP will function normally. Check this article on how the vPC peer switches will function in respect to STP with and without peer-switch: https://www.cisco.com/c/en/us/support/docs/routers/7000-series-routers/116140-config-nexus-peer-00.html
I strongly recommend you to enable mac move notification. This will help you in RCAs in case something happens in the network. Regarding storm control.. well. This feature requires some network analysis before enabling it. More specifically you need to know the expected percentage of unicast/broadcast/multicast traffic in your network. If you do not know that, I would not recommend to enable it.
Yes. Orphan port means a non-vpc configured interface. Basically, if you do not configure vpc, you will have 2 different interfaces/port-channels between N5K and catalyst stack.
N5K1: interface po10 switchport mode trunk vpc 10 interface e1/1 channel-group 10 N5K2: interface po10 switchport mode trunk vpc 10 interface e1/1 channel-group 10
N5K1: interface e1/1 switchport mode trunk N5K2: interface e1/1 switchport mode trunk
Note: in non-vpc example, if you configure port-channel, make sure you have different port-channel number on the two N5K switches. But again, there is literally no advantage of having this config. Quite the opposite.
Cheers,
Sergiu
04-20-2020 05:57 AM - edited 04-20-2020 05:59 AM
Yes, you can configure vPC over dark fiber. vPC is just a Layer 2 virtualization technology, so it will work normally as it should.
Better go with the trunk between the Catalyst and Nexus.
vPC has built-in loop prevention mechanisms, so you do not have to worry about this. You can however improve the convergence in the network through the use of vPC peer-switch features (in case your Nexus switch is the STP root).
If there is a layer2 loop in the network, there are a couple of features which can minimize the impact:
- disable mac learning if mac is flapping on high rate between different ports:
- storm control:
You can leave the ports configured as normal orphan ports, and STP will take care of the loop/fail over, BUT there is NO reason nor advantage to do this. vPC is one of the most mature and stable feature on Nexus switches. You should go for it.
Cheers,
Sergiu
04-20-2020 07:16 AM
Hello msdaniluk,
Im happpy and honored that you reply so fast and effectively to my question thank you man so :
- storm control:
Cheers,
Cheers
04-20-2020 09:10 AM
Cheers,
Sergiu
