Failed Identification Test
Khurram Tariq
Dear All
we are facing following error while configuring HWIC-2FE in cisco router 3845,
IOS version is: 12.4(24)T7
here is the error message when i did "Sh diag"
WIC Slot 2:
        Failed Identification Test [ 7/0 ]
        2 Port FE HWIC
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-33018-01
        Part Number              : 73-12949-01
        Unknown Field (type 008A): 41 30 00 00
        Deviation Number         : 0-0
        Fab Version              : 03
        PCB Serial Number        : FOC17010BWF
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-2FE
        Version Identifier       : V02
        CLEI Code                : COUIAFUCAB
        Base MAC Address         : 0000.0c4f.3100
        MAC Address block size   : 2
        Connector Type           : 01
ghostinthenet
Level 7
Level 7
Your IOS version certainly supports the HWIC-2FE (minimum 12.4.20T required) so that's not a problem. I've seen this before with bad cards and/or HWIC slots. Are you getting the same error no matter which slot you're installing the HWIC into?
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
No i did not check it in another port but checked in one port only
Give it a try in another slot and see if you get the same results?
