03-06-2009 12:41 PM - edited 03-06-2019 04:26 AM
Attempting to build a 6509 with Supervisor 2s in module 1 & 2 - OS is
CatOS 8.5.2.
When powered on with both sups in place, the system keeps repeating "Failed in stat 0" and will not start. We moved the modules to a 6506 and it booted properly.
The 6509 will boot with a single Supervisor 2 in module 1. We suspect a hardware issue with the chassis - is there anything we should check before opening a TAC case?
03-06-2009 12:52 PM
What happens when you boot with one installed, allow it to load, then insert the second module.
If it stays up, issue the command :-
show module 2
to get some more details.
03-06-2009 01:11 PM
We had tried that. The switch stayed up, but didn't see module 2 at all - not listed when we did "show module"
