fan assy for a 3725
brian.windle
We have a bad fan assy for a 3725 router. I'm in the process of ordering a replacement for it however I can only find the one for the 3745 router or CISCO3745FANASSY=
Does anyone know if this is interchangeable in the 3725?
TIA
Brian
Not applicable
There is no part number for the fan in a 3725 chassis. If the fan has gone out it will be necessary to replace the whole chassis.
magnaroute
If the router is not under SMARTnet, there are companies selling fan replacement kits for the 3725.  Search google and you will find them.
